Woods Pulley Bearings
Gator
08-29-2003 14:55:30
Has anyone replaced the sealed ball bearings in the two belt pulleys on a Woods belly mower? I'm having trouble locating replacements and the originals do not have any name or numbers on them.
Thanks in Advance!
Gator
09-02-2003 15:37:35
 Re: Woods Pulley Bearings in reply to Gator, 08-29-2003 14:55:30
Thanks to all who replied. I'll contact Woods Equipment and see if they will ship the bearings.
allan b.
08-29-2003 23:56:35
also if you do contact woods equipment co. ask them for a parts and parts number catalog. allan b.
allan b.
08-29-2003 23:43:25
you may want to contact their company and order direct, or they can give you the phone and address nearest you. but their company headquarters phone number is 815-732-2141 or fax number is 815-732-7580. the address is 2606 south illinois route 2, po box 1000, oregon, illinois, 61061. their web address is www.woodsonline.com ..... .maybe they can make it easy on you and send it to you direct or have a local dealer get the parts for you. usually they ship in 3 days. hope this helps allan b.
Dieselrider
08-29-2003 16:42:27
Try Gipson Bearing in Pittsburgh, Pa. Gipson Bearing & Supply Company Inc 980 Forest Avenue, Pittsburgh, PA 15233 (412) 793-7673 They can usually match you up with a bearing if you have the ID,OD, and the thickness. Good luck.
Gary
08-30-2003 05:44:58
 Re: Re: Woods Pulley Bearings in reply to Dieselrider, 08-29-2003 16:42:27
All bearing supply houses do this.
