Model 78 Square Baler
Lawrence in Tex
08-27-2003 14:05:25
I have almost finished cleaning up my New Holland 78 baler.The only thing I cannot figure out is where a rope or cable goes and what does it do?It has something to do in locking and lowering the hay pickup.Does the shaft coming from the gear box located above the packing chamber have the rope or cable go around it? I could use and apreciate any help.Thanks Ahead.I have a manuel ordered but New Holland doesn't think I need it.
Wayne in Pa
08-27-2003 14:52:25
 Re: Model 78 Square Baler in reply to Lawrence in Texas, 08-27-2003 14:05:25
The rope is indeed used to raise and lower the pickup. You use naylon rope one end tie to the metal bar that comes up from the pickup (the bar has a notch in it to catch on a loop that will hold up the pickup). Then take the rope around the shaft that goes from the gear box ( it has a windlass spool) wrapped 31/2 times then through the metal cover to the tractor. That is how it is worked on my 280 they are wery simerlar. I hope this helps. When the bayler is running to rase the pickup you pull on the rope, when the pickup is all the way up you release the rope suddenly and it will latch. A slight pull on the rope and then a gradual release will unlatch the lift strap so the pickup can be lowered. It is a good idea to keep the rope oiled at the windlass.
