Massey Harris Model 28 -3 furrow plow
Ken
08-27-2003 07:26:54
I have the chance to buy this plow, but the tires
are gone. From the information I have found, the plow requires tires with a lug type tread on the front. Does any know the size of front tires that were on this model of plow originally.
Also require a rear tire and need tire size for it also.
Thanks for all replies
JIM
08-28-2003 03:49:11
 Re: Massey Harris Model 28 -3 furrow plow in reply to Ken, 08-27-2003 07:26:54
Both front tires are 6.00 x 16 with tread on the land side and a rib tire in the furrow assuming it is not hydraulic lift and still has the origional rims. The rear tire is 3.50 x 12. The 4 & 5 furrow used different tires.
Jim
Leroy
08-28-2003 06:10:36
 Re: Re: Massey Harris Model 28 -3 furrow plow in reply to JIM, 08-28-2003 03:49:11
A 4:80 x 12 trailer tire will work
Rob
08-27-2003 11:18:53
I can't answer your questions but you perked my interest to go and look at an old M-H three bottom plow on steel that I acquired quite some time ago. It's got a bent beam and doesn't plow worth a dam. It's made in Canada and is marked "Patented 1942". I can't make out any of the other writing-too faded. The castings are all stamped "PE ###" Anybody know what model and vintage it is?
