Little genius rim for drag wheel?
Bob (NE Ohio)
08-26-2003 14:03:04
Hi. I've got a little genius 2-14 and I need to replace the rim on the small drag wheel. Does anyone know where I can get one? My welder said it wouldn't take the heat. I'm running out of options. Please help.
farmerjohn
08-26-2003 19:47:22
 Re: Little genius rim for drag wheel? in reply to Bob (NE Ohio), 08-26-2003 14:03:04
You could try Bakers Farm Equipt. 724-254-6400 They have a parts yard. Located in western PA
Keith Miller
08-26-2003 14:55:56
I wasn't able to find one but I bought a rim, cut the center from the old one and welded it in the new one. Miller tire has rims. buy the blank rim with no center. MIller tire is no relation to me, but I have done business with them and can recomend them.
Keith Miller
08-26-2003 14:58:22
 Re: Re: Little genius rim for drag wheel? in reply to Keith Miller, 08-26-2003 14:55:56
Maybe I was assuming too much when I assumed you had tire wheels. If you have steel then you need another gameplan.
Bob (NE Ohio)
08-27-2003 12:27:53
 Re: Re: Re: Little genius rim for drag wheel? in reply to Keith Miller, 08-26-2003 14:58:22
I'm still figuring out my plow terminology. What's the difference btw tire wheels and steel. The rim I have is empty in the middle and it clamps and bolts onto a steel disc.
Keith Miller
08-27-2003 13:53:34
 Re: Re: Re: Re: Little genius rim for drag wheel? in reply to Bob (NE Ohio), 08-27-2003 12:27:53
Does your plow have wheels with rubber tires or is it steel wheeled? my Little genius has rubber tires. It isn't painted the correct color but I could take a picture in several days to help with the explanation. But that will have to wait till after the weekend. Our daughter's wedding is saturday.
Bob (NE Ohio)
08-27-2003 18:49:03
 Re: Re: Re: Re: Re: Little genius rim for drag whe in reply to Keith Miller, 08-27-2003 13:53:34
I guess that wasn't as complicated as it sounded. My plow has rubber tires. Enjoy the wedding!
Bob (NE Ohio)
08-27-2003 18:48:29
