IH Model 70 Plow and gear oil
Rich
08-25-2003 07:31:06
I now have a clutch lift Model 70 IH plow (four sixteens). What years was the Model 70 made? My other question is about the oil in the clutch lift. The owner's manual says 40 weight oil goes in there. I don't have a problem with that. I am just curious why it is not gear oil (80 or 90 weight). Would I hurt or help things using gear oil?
Thanks much.
Hugh MacKay
08-25-2003 19:47:11
 Re: IH Model 70 Plow and gear oil in reply to Rich, 08-25-2003 07:31:06
Rich: I would tend to stick with what the manual has to say on the oil. The problem with these larger clutch lift plows is enough wheel traction to do its job. It was never a problem with 2 bottom plows, 3 bottom were not too bad and 4-5 bottom not good. Of course wet and dry days made a difference. So best keep that clutch working free as possible.
The number 70 plow came out about 1962 or 63. By 1975 it had become the 770 and that version was still around in 1984. The plow never changed much over the years except for hydraulic lift and automatic reset bottoms.
