What Size Disc Mower?
BobbyB
08-20-2003 19:05:48
I have a 52 hp. Case 595. What is the largest disc mower that I should consider? I have been told 8 feet, because of the weight of a disc mower.
Thanks.
Cliff Neubauer
08-21-2003 12:48:23
 Re: What Size Disc Mower? in reply to BobbyB, 08-20-2003 19:05:48
We have a 9' NI 5409 and use it on either an IH 1066 or 1086 that are running a strong 150 hp and to be honest I wouldn't want a much smaller tractor on it. We have alot of big hills and tractor weight is just as important as the hp. We generally mow 8+ mph and I have ran as fast as 19 mph which is where the extra power really comes in handy. I would think you would have enough power for an 8' mower as long as you don't get in too much of a hurry and you should be able to add front weights to that tractor if you need them for stability.
Roy in UK
08-21-2003 14:09:50
 Re: Re: What Size Disc Mower? in reply to Cliff Neubauer, 08-21-2003 12:48:23
Mowing at 19 mph? Good grief!!!!! !!!!!
Roy in UK
08-20-2003 23:32:04
8' should be enough. Have used a Vicon 8' on an MF 165 (A4-203 engine)with no problems if the the hay was not too thick. If you mean your tractor is 52hp at the P.T.O. then it should be OK. Could you ask your dealer if you can have a mower to 'demo' ( try out) just to see if it would be suitable for you? I have found that the Lely is an easy mower to spin, I believe in U.S.A. they are marketed as Vermeer.
Hay Dr
08-21-2003 05:11:58
 Re: Re: What Size Disc Mower? in reply to Roy in UK, 08-20-2003 23:32:04
Hello Roy,
We sell both the Lely and Vermeer. There are a few differences but 95% the same mower.
Chas in Tn.
08-20-2003 22:33:57
I prefer the 7'-10" or the 8' size works well with most tedders too.
kyhayman
08-20-2003 19:10:21
8' will be all you'll want in good hay. I've got a 65 hp and 2 85 hps and an 8' disc mower pulls mighty hard on the 65. Every time I buy a new one I get to wanting a 9' but my dealer keeps talking me out of it. He has a point, with the bar up a 8' bar is as tall as my tractor cab.
Hay Dr
08-20-2003 20:04:43
 Re: Re: What Size Disc Mower? in reply to kyhayman, 08-20-2003 19:10:21
The 8' is the best size sold. Many of the 9' and beyond 3 point mowers have frame problems and or safety release problems. Take for incidence the Fort & Morra mowers on their 9' mower when safety is tripped it will 50% of the time cause PTO damage leaving the farmer dead in the field needing expensive repairs.
