Pitman Arm wood type?
Kent
08-19-2003 08:19:37
I have a Case model 10 sickle mower and my local Case/IH dealer says the arm is back ordered and is trying to locate one for a spare. I have a pretty good one on the mower and thought I would just make one. What kind of wood would you use, Oak, Hickory, Hard Maple ??? Thanks Kent
Old Iron
08-20-2003 15:51:59
 Re: Pitman Arm wood type? in reply to Kent, 08-19-2003 08:19:37
Kent,
The factory I order pitmans from uses Hickory and Hard Maple to make their pitmans. I'm not sure but I think they use WD40 to seal them when they are done making them.
My 2 bits worth,
Old Iron
willyz
08-24-2003 05:52:15
 Re: Re: Pitman Arm wood type? in reply to Old Iron, 08-20-2003 15:51:59
WOW! Something WD40 might actually be good for.
Kent
08-20-2003 14:28:58
Thanks Men. Thats what I like about this site, there is always a wealth of information. I appreciate the help. Kent
Kent
08-19-2003 19:56:37
I thought I would make it out of some oak scraps that a buddy has in his wood shop and then soak it in a bucket of waste oil. Please don't turn me in to the EPA !! Thanks for the suggestions. Kent
Ben in KY
08-20-2003 12:26:45
 Re: Re: Pitman Arm wood type? in reply to Kent, 08-19-2003 19:56:37
Oak should work fine, Hickory would probably be better though if you have it. If you want to stay clear of the EPA use boiled linseed oil on it.
Doug
08-20-2003 09:55:58
Red oak is mainly for indoor furniture because it rots quick. If you have white oak, use that. White oak will last a lot longer with or without the oil.
dhermesc
08-20-2003 11:33:47
 Re: Re: Re: Pitman Arm wood type? in reply to Doug, 08-20-2003 09:55:58
I made a pair out of a broken pallet, I think they use white oak to build them. The wood they use in GOOD pallets is extremely tough and durable (plus it was free from work).
bob
08-19-2003 21:15:16
That should work. Ones I have seen were red oak.
ChrisL
08-19-2003 19:45:11
I made several at a time - made them out of the green treated deck lumber - had it outside and been on the first one now for a couple of years - looks as good as new...
Bigdog
08-19-2003 08:58:20
Ash is excellent.
Steve (Magnolia, TX)
08-19-2003 08:30:35
I thought that hickory was pretty much the standard... maybe ash...
Steve
