NH 451 Mower vs NH 450
SmallOps
08-18-2003 03:13:33
Can anyone tell me the difference between the NH Model 451 Sickle Mower and the NH model 450?
SmallOps
08-19-2003 03:52:37
 Re: NH 451 Mower vs NH 450 in reply to SmallOps, 08-18-2003 03:13:33
Thanks guys! I am now educated. Thanks Dave for reposting the 22 July discussion on this mower!
Dave
08-18-2003 19:11:27
I asked the same question back on July 22! Here are the replies that I received then:
From Steve from New Holland 04:34:33 07/23/03 Dave, TN dealer is basicly correct on the length of the bar, but early 451 mowers were the same length as the 450. 450 and early 451 knife assemblies were 28 sections long. later 451's were 29 sections long. The 450 came out in the mid 1950's and the 451 came out in the mid 1960's and New Holland has not changed model numbers since. The real main difference between the two is the bearing setup in the pitman unit. The 450 used needle bearings and the 451 uses tapered roller bearings. 450 pitmans are easier to work on, but then again, you will probably need to work on them more often. However, the 451 pitman unit is NOT failure proof either. Steve
From: East TN Dealer 21:40:32 07/22/03 One more section on the NH451 and the rest is about the same
Roy B
08-18-2003 17:56:02
The 451 uses one more section than does a 450 of the same length. My 450 is a good working machine. Roy
jw 57
08-18-2003 04:58:38
I believe the Differance was age-the 450 was made in the 60's and it also came with a pto shaft in back which allowed some to pull a crimper or roll conditioner behind as you cut.
Robert in W. Mi
08-18-2003 13:17:34
 Re: Re: NH 451 Mower vs NH 450 in reply to jw 57, 08-18-2003 04:58:38
My 451 has the pto out the back, so it couldn't have been on just the 450's.
I don't know the difference, but there was two bar lengths, maybe that's it???
Robert
