Ford 101 plow
Orren Winjum
08-18-2003 02:11:55
I have, what I believe to be, a Ford 2-14 Shearpin bottom plow Model 101 with lever adjustment.
Do you know where I might get an operator's manual and/or a parts diagram?
Thanks very much for your help.
Best regards,
Orren Winjum
Jerry D in NC
08-19-2003 10:55:27
 Re: Ford 101 plow in reply to Orren Winjum, 08-18-2003 02:11:55
Tom has given you the right answer but until your manuals arrive I can give you some details about your plow if you will get me the info from the silver plate that should be right behind that "Width of cut" adjustment lever. It will probably be 10-337 or 10-458. That lever is an excellent feature if you are plowing any hilly land. The width of cut can be adjusted as you go from steep to level and works great. The 101 series is an excellent plow for a 30hp like a 2000 Ford or the Jubs or 6XX series. They will plow great and the wear parts are very available and relatively inexpensive.
Tom A
08-18-2003 04:55:33
Call New Holland pubs department, they sell reprints of manuals for just about all the old Ford, Dearborn and NH equipment. They're at 800-635-4913. Pretty reasonable, most of the ones I've bought were around $10-15, including postage.
tom
