John Deere 800 windrower
Steve Boe
08-13-2003 16:48:09
I picked up an old JD 800 windrower. I have ordered the manual, but before it gets here I'm trying to tighten a few things up. Anyone familiar with maintenance on these things? I need to tighten the ground drive chains. They are real loose. Any info would be much appreciated.
Steve Boe
Bob
08-13-2003 17:26:26
 Re: John Deere 800 windrower in reply to Steve Boe, 08-13-2003 16:48:09
Make sure the chains are not worn excessively before wasting time tightening them. If there is any question of wear, now is the time to replace them.
The outer chains are tightened by putting shims under the pillow block bearing, and the inner ones are tightened by moving a bearing flange.
Each adjustment will affect the other to a small degree.
Make sure there is a small amount of 80-90 oil in the steering planetaries, and change and refill the oil in the sickle drive wobble box.
Steve Boe (WI)
08-14-2003 18:13:55
 Re: Re: John Deere 800 windrower in reply to Bob, 08-13-2003 17:26:26
Thanks for the info Bob. I tightened the chains and greased her up good. Cut 20 acres of oats today. It worked just fine.
Steve in Wisconsin
