super c disk
joe
08-13-2003 08:58:32
would a super c fast hitch disk work on a farmall 340?
Harold Hubbard
08-14-2003 03:36:49
 Re: super c disk in reply to joe, 08-13-2003 08:58:32
Yes it will, but: I think the prongs on Super C implements are smaller than those on the 340. I have a 330, and to use Super C implements I have to put filler strips in the sockets on the tractor. IH sold sold them as an accessory, but you can make some from a couple strips of steel.I don't have the dimensions available, but measure the prongs and the sockets from top to bottom, the difference is the thickness of the required strip. There is a hole through the socket for a retaining wire or clip, and the back of the strip should have a shoulder so it doean't get pushed in too far when hooking up the implement. The operators manual does caution you against overpowering the smaller implements when you use them on a larger tractor, but common sense will keep you out of trouble.
