Ripper Plow
TC
08-12-2003 13:30:01
There is a Ripper Plow in the photo ad section .
Is the purpose of a Ripper Plow to up-root all the stones and roots in the soil before you use a regular plow ?
Thanks,
Tom
Shep Va
08-13-2003 10:04:30
 Re: Ripper Plow in reply to TC, 08-12-2003 13:30:01
third party image
As Paul said those type of ripper plows are all that is used on the larger more modern farms of today. The conventional plow is too slow and does not break up compaction like the rippers do. The one in the photo ads is a small one, most of the ones you see today can go 15 inches or more deep, be pulled at 5+ MPH in the field and are desiged to break up soil compaction and break hard pan left by moldboard plows and offset discs.
Our farm has been running a 5 shank ripper for the last three years and we can see a big difference in the crops from the fields that get ripped and the ones that have not yet. In a few years you will not see a conventional plow or even a disc on a moderen farm as the rippers and field cultivators have simply replaced them
TC
08-13-2003 18:32:11
 Re: Re: Ripper Plow in reply to Shep Va, 08-13-2003 10:04:30
Thanks for all the information on Ripper Plows .
Sounds like they do a great job.
I am in the process of recaiming a old mowing.
I would like to turn it over and plant it for hay.
I know Im going to find alot of stones big and small! Is there a implement for purpose ! Or is it just go real slow with the plowing ?
Thanks again,Tom
Shep Va
08-14-2003 05:36:29
 Re: Re: Re: Ripper Plow in reply to TC, 08-13-2003 18:32:11
I normally dont worry too much about running a ripper through rocks and stumps and such. The ripper will tend to bring rocks and such to the surface, and if it hits one that is too big, most have spring resets and shear pins to protect the ripper from getting broken. I have gone over some of the rocks, have brought some up and broken others, and in one field on the second round I break two shear pins in the same place every time, so there must be a big rock under there somewhere.
Then the hard part is you need to go back over the field with a loader or cart and pick them all out of the field, or if im in a hurry I take the roller harrow and run over it a few times and push all the rocks back in the ground. Not the best idea but it works until you can get them all out the next time.
Jerry (AL)
08-13-2003 11:18:27
What type of HP would be needed to pull a ripper measured per shank I assume?
Shep Va
08-13-2003 11:35:01
 Re: Re: Re: Ripper Plow in reply to Jerry (AL), 08-13-2003 11:18:27
It kinda depends on your set up, how deep you are running, soil type and compaction. On my DMI machine they claim it takes between 18 and 24 HP per shank to pull it. OK if the front 4 shanks are going in 7 inches with streight points and take 18 HP each thats 72HP. If the back 5 winged shanks are going in 15 inches or so and take the full 24 HP to pull thats another 120 Hp. Add that up thats 192 HP on average to pull my ripper and I do it with a 200 HP tractor, so that is close to right for an average. Some fields it is easier to pull and some it is a lot worse and I end up pulling slower or running shallower.
It takes a lot of HP to pull these machines but they do break up the hard pans and the soil compaction and you can visibily see it in the crops the next year.
paul
08-12-2003 15:28:57
It rips up compacted soil. Lets air & water in, helps drainage, helps roots grow in the root zone. Big outfits of today are the only heavy tillage used, I would assume no plowing was done in olden days either.
--->Paul
John A
08-12-2003 14:16:12
TC, The purposeof this ripper is to aireate (ms) the root system on pasture grass. Native or Improved, it will help in falage production for grazing or haying. Hope this helps,
Jphn A.
