Seeking source for replacement disk blades
ShepFL
08-11-2003 12:59:23
third party image
for my new ground plow aka pan plow. I rednecked me a plow last yr. but over the summer I broke the rear disk. The existing blades are very thin.
I am looking for a pr. of replacement blades. I am seeking .25" thick by 26 inches tall. I figure the thicker they are they should hold up longer.
paul
08-12-2003 15:21:04
 Re: Seeking source for replacement disk blades in reply to ShepFL, 08-11-2003 12:59:23
I'll guess there are different hub hole / bolt spacing sizes, you might as well get your info together on that right away be4 you start calling. If I recall, you don't know what brand it is, do you?
--->Paul
Jerry D in NC
08-12-2003 11:28:14
Hey look now I was not the first one to mention Agri Supply, however they do have some 26" 8mm thick discs but I don't know how they attach to the plow. They might work for you.
wh
08-11-2003 17:51:45
try agri supply in norht carolina. have store elswhere also. you can find them with an internet search. i believe they are listed as agrisupply.com have bougth several things from them over the years and been real pleased with service, wade
Nebraska Cowman
08-11-2003 17:42:54
I don't know about hole size but that is about the diameter of the field disks the big boys use. The thickness shouldn't matter anything that big will have to be built heavy enough to take the strain. Check with an impliment dealer.
