488 haybine chain
mm
08-11-2003 06:09:23
How tight should a chain be i.e 1/2 inch play like a belt. This chain is #40 on the the reel. But is there a gerneral rule of thumb like a belt Thx
David
08-13-2003 19:13:45
 Re: 488 haybine chain in reply to mm, 08-11-2003 06:09:23
MM ,Dont get it over tight,will make the chain run hot,if it gets real hot it will cause wear on the sprockets and chain . I always turn the pivot till the chain is tight,then back it off just a little, David
kyhayman
08-11-2003 17:42:19
Roller chains need to be tight. If the chain whips when running it needs to be tighter. Donn't want to over tighten but that's hard to do. I use a crowbar as a lever to tighten my idler.
