NH 68 Baler.....Pros Cons, Please..
Bear
06-24-1999 08:15:27
Farmer Brown wants $500 for NH 68 baler; needs idler pully repaired on chain drive to
pickup unit. What's good and bad about this model?
kevin
06-27-1999 15:35:10
 Re: NH 68 Baler.....Pros Cons, Please.. in reply to Bear, 06-24-1999 08:15:27
What tractor are you going to use? You will need s l o w ground speed if you are in even remotely heavy hay. I had a 68 and was glad to see it go.
Mine didn't like heavy hay and the plunger speed was far slower than I would have liked. Never tied correctly. I think $500 is too high, they bring $150 at auction around here. For my money, there are other balers worth looking at, I had good luck with a Massey model 12, it baled faster and made far nicer bales than the 68.
I guess I am a little jaded, the 68 was my first square baler after selling my Allis Roto-Baler which I dearly loved, although most people hate them! I think I got spoiled by the Allis ability to digest HUGE windrows compared to a 68. In fact, I went back to a Roto-Baler, and loaned the Massey 12 to my brother. I think the pre model 273 NH balers are grossly over rated.
B.C.
06-29-1999 07:04:56
 Re: Re: NH 68 Baler.....Pros Cons, Please.. in reply to kevin, 06-27-1999 15:35:10
I think that any of the square balers from that era were about the same when it came to baling rate. I'm going by the experiences that we had with the Deere 14T before we went New Holland. And we switched because we had moved, not because we woke up one morning and decided to damn Deere.
They all want fairly uniform windrows and yes you can put too much through them by either rolling up too much in the windrow or hitting it too fast or some combination therein. The quick fix to that problem is as you imply a bigger capacity baler and the key to that is real simple, it's more of that green stuff.
Lemme know where those $150 68's are at, I'd like a few more.
kevin
06-29-1999 07:36:39
 Re: Re: Re: NH 68 Baler.....Pros Cons, Please.. in reply to B.C., 06-29-1999 07:04:56
NH 68's at auction in Greene County PA $150.00.
I'm well aware of how raking technique affects baler performance, but there were balers around with higher plunger speeds than a NH 68 or JD 14T.
Jim
06-26-1999 00:19:57
We have a 69 baler which is close to a 68 Its work well gives little trouble.But I would suggest if you buy it replace the plunger stop spring.We haven t use are baler for a number of years til this summer and that spring broke. Well to say the least the plunger and needles don t mix well need I say more. Like the other guy said New Holland I think is the number one choice in hay euipment.
B.C.
06-25-1999 06:06:42
We've got one. We used to use a NH66, and before that we had a Deere 14T.
The only bad thing I can say about NH is that some of the parts (needles, knotter stuff) are expensive, at least compared to what we used to pay for corresponding Deere stuff. We haven't had to replace anything of real consequence on the 68 in the 5 or 6 seasons we've had it. (The NH66 was a different story). We hook on the 68, use it a few days, then rustoleum or grease the shiny parts and park it for another year. NH is good about manuals, parts availability.
Some might note that the hay pickup and transfer parts groups are more elaborate than what the other people did. I think they work better as a result.
Other than that, they are the first name I think of when it comes to haying equipment.
Dennis H.
06-24-1999 11:19:17
Parts are still available, they are simple to work on, they work well and are cheap to buy. Make sure you get an owners manual and it should have enough grease fittings on it to keep you busy most of a morning keeping it greased. But that is always easier than fixing what didn't get greased. You would have to ask someone else for a con, I really like these balers.
