271 Hayliner Tire
ChrisL
08-09-2003 16:49:24
Just got a Hayliner 271 at a sale the other day - $75 and it has two new tires on it..... ..
However - problem number 1 - when we put the pickup down to working position the end of the center axle for the pickup teeth rubs on the edge of the tire - what is supposed to keep the tire a little further out? it looks like the right hub, right size tire etc....
Garry
08-09-2003 20:05:47
 Re: 271 Hayliner Tire in reply to ChrisL, 08-09-2003 16:49:24
could be as simple as taking the tire/rim off - turn it around & put it back on..... ..sort of like adjusting spacing between the front tires on a wide front end tractor..... .will move the tire in/out a coupla inches or so...
Garry
tlak
08-09-2003 17:11:58
They probably put standard 15" truck tires on it. You need to look in your manaul and it will probably show something like 5.40x15 and 6.00x15 for the other side.
