Trailor
Dick A
08-09-2003 15:49:11
A friend was driving behind me and tells me that my two wheel trailer is weaving 2 to 3 inches from left to right. Is this alignment or weight distributiom? Thanks
screaminghollow
08-11-2003 13:01:38
 Re: Trailor in reply to Dick A, 08-09-2003 15:49:11
It is a most aggrivatin problem. My flat bed trailer weaved like a drunk on New Year's mornin' behind my 83 Suburban, but behind my F-250 Ford don't weave at all. Did not matter where the load was front, back or sideways. I heard of load placement making a difference, alignment etc. Can't explain why it pulls straight and steady behind the ford but not the Chevy.
Joe (Wa)
08-11-2003 21:07:52
 Re: Re: Trailor in reply to screaminghollow, 08-11-2003 13:01:38
Perhaps you have passenger (P) tires on the chebby and truck (LT) tires on the dorF? The stiffer sidewalls & higher air pressure sure helps prevent the initial motion and dampens it out better should it occur.
Fighting suburbia in NC
08-10-2003 20:18:18
Check your trailer wheel bearings for being too loose. If weight gets a little too far back and bearings are loose you can be in for a interesting ride.
Old Iron
08-09-2003 21:46:07
Dick,
I don't know what you have or what you were hauling but I would guess if it doesn't usually weave you had the load too far back.
My 2 bits worth,
Old Iron
trailer
08-09-2003 18:18:19
duuh yeah, could be. Where were you?
