NH 270 timing
mfman
08-08-2003 20:28:54
On my NH 270 there are timing marks to check the feeder fingers, and timing marks to check the knotters, but no marks to line up the crank. The sticker is partly worn off that tells the timing procedure and my manual is backordered at NH. Do I need to place the crank at 90 degrees (straight up) to the baler to check the timing? Thanks!
Steve from New Holland
08-09-2003 04:30:07
 Re: NH 270 timing in reply to mfman, 08-08-2003 20:28:54
Yup! Just eye it up the best you can and that will be close enough. Steve
mfman
08-09-2003 07:08:53
 Re: Re: NH 270 timing in reply to Steve from New Holland, 08-09-2003 04:30:07
Thanks again, Steve.
