NH 270 flywheel shim
mfman
08-06-2003 21:19:14
I removed the flywheel and replaced the front seal on the gearbox on this baler. The bushing in the flywheel was toast so I replaced it also. When I got it apart there were 3 washer/shims between the flywheel and the gearbox. One was worn paper thin. According to NH dealer only 1 shim is shown in parts diagram, but he said to take up the slack here if there is any. If I use one new shim, the flywheel looks like it will rub the frame. But if I use 2 new ones, it holds the flywheel so tight that I can't turn it by hand. If I shear a bolt, I'll have to hold the pto shaft with a bar to turn the flywheel to replace the bolt. Anybody know how many shims are suppose to be here? Any ideas?
paul
08-07-2003 08:38:43
 Re: NH 270 flywheel shim in reply to mfman, 08-06-2003 21:19:14
Sounds like 1 new one & one old one will work out just right for you????
--->Paul
Steve from New Holland
08-07-2003 04:29:02
mfman, there is no set amount. It does not matter if there is not enough shims, but you do NOT want too many making the flywheel tight. I know the flywheel may rub the frame when you shear a bolt, but it really doesn't hurt anything. So, if you have to choose, take a shim out. Steve
mfman
08-08-2003 14:56:23
 Re: Re: NH 270 flywheel shim in reply to Steve from New Holland, 08-07-2003 04:29:02
Thanks Steve. I'll think I'll just go with 1 new one then.
