hay dogs
MF-Man
08-02-2003 20:49:55
I need to ask a stupid question. I have been reading back through the old posts and seen the term used quite often. Exactly what are the "hay dogs"?
Garry
08-03-2003 16:28:36
 Re: hay dogs in reply to MF-Man, 08-02-2003 20:49:55
Hay dogs in my Ford 542, bottom dogs (3) are easily seen protruding up through the bottom of the bale chute just before the compression face of the plunger. The top (2 spring loaded, 1 stationary) are directly above, but do not show as well:
third party image Note slots in plunger face to accomodate plunger going past haydogs on return.
Links to images showing the top hay dogs on my NH273. One image shows (red outlines)the top hay dogs from the out side. The other shows the top dogs doing what they are supposed to do. Don't have an image referencing the bottom hay dogs, but they are directly below the tops. On the 273, there are 3 spring loaded on top & 2 spring loaded on bottom with 1 small stationary (small wedge welded to the floor of the bale chamber) for the 3rd.
(Images should open in a new window)
Image 1
Image 2
Garry
MF-Man
08-03-2003 17:10:23
 Re: Re: hay dogs in reply to Garry, 08-03-2003 16:28:36
Thanks a ton Garry! I've looked everywhere for a picture showing these. All 4 on my NH 270 are stuck and the springs are broke on 2 of them. Guess it's from previous owner leaving hay in the chamber during storage. Another trip to the good ole NH dealer I guess.
red-n-green
08-03-2003 06:05:19
My hay dogs are a beagle and a fiest. Whenevr I cut the field behind the house, they follow me looking for rabbits!
willyz
08-03-2003 05:25:06
Hay dogs are like little levers that are usually spring loaded. The protrude into the bale chamber of a baler. Their purpose is to prevent the hay from springing back when the plunger pushes the hay into the chamber. When one is missing or the spring is broken you will usually have tying problems, maybe not every bale, but on every second or third bale. The problem is most apparent on dry stiff hay and not as bad on damper hay. On a MF baler if I'm having knotter problems, first I check the springs on the knotter and the ones on the path from the twine box, then the hay dogs.
Errin OH
08-03-2003 05:14:55
Basicly they are spring loaded wedge. Hay is pushed past them as the plunger compress's and cuts. When the plunger returns and the next batch is fed in they hold the compress hay back to prevent the hay from following the plunger back up and blocking the feed chamber. They also help keep the bale square. On my old ford there are two on top and three on bottom. If you loose a spring (say on bottom) you'll get odd shaped bales and have pluging problems.
MF-Man
08-03-2003 07:27:00
 Re: Re: hay dogs in reply to Errin OH, 08-03-2003 05:14:55
Are they spring loaded on NH balers? All I see in my bale chamber on my 270 are 4 wedges, but they look like they are just bolted to the sides of the chamber. I don't see any springs. I need to replace 2 of the 4 as they are rusted apart in the middle.
Ridr
08-03-2003 08:12:22
 Re: Re: Re: hay dogs in reply to MF-Man, 08-03-2003 07:27:00
I would think a 270 would have them , older NH's do ..Look behind the knotters and on the bottom of the chute
MF-Man
08-03-2003 08:24:38
 Re: Re: Re: Re: hay dogs in reply to Ridr, 08-03-2003 08:12:22
Ridr, I took a walk out to have a look at my 270. You're right, it has 2 on top and 2 on the bottom. All 4 are horizontal right now. What makes them protrude into the chamber to hold the hay from backing up? Are they suppose to be sticking into the chamber all the time? I'm trying to learn all I can as this is the first baler I have owned. Always borrowed before. I ordered a manual, but its backordered and I'll probably have to bale second cutting before I get it.
