Disc Mowers
JC
08-02-2003 06:11:30
Does any company make a 7' pull behind discmower
with either rollers or fingers for conditioning.
All I ever see is 9' and larger or the 3pt type.
My gates and roadways on the farm are too narrow
for anything bigger then 7' and I'd like to move
to a disc mower instead of a haybine. Thanks.
Chas in Tn.
08-02-2003 19:36:22
 Re: Disc Mowers in reply to JC, 08-02-2003 06:11:30
Vicon made a 7ft 10in KM 240 mower conditioner, I have one that is 19 years old, has been an excellent machine and tough! These machines had drive shaft problems, big time!! I solved this myself, put an 80 degree on her ($750.00) My cutter bar has only been open 2 times, last time I replaced all bearings and seals, Gears are still original. I like the 3 blade system also. You should be able to buy one of these machines cheap, because of the driveshaft problem. Also parts are still available.
Roy in UK
08-02-2003 11:10:50
Why trailed? is there any reason that you do not like 3 point mounted disc mower/conditioners?
JC
08-02-2003 19:36:14
 Re: Re: Disc Mowers in reply to Roy in UK, 08-02-2003 11:10:50
Easier to hook to tractor and the New Idea I have
now is very heavy on the 3pt, also no conditioner.
paul
08-02-2003 15:09:13
Are there any 3-pt _conditioner_ units????? Lots of mowers, but not with a conditioner included?
--->Paul
Hay Dr
08-03-2003 20:50:50
 Re: Re: Re: Disc Mowers in reply to paul, 08-02-2003 15:09:13
We've sold a few Lely 3 point mower conditioners but it not as good a unit as the pull type ones.
Roy in UK
08-02-2003 16:06:42
Available in UK but I dont know about USA / Canada
Roy in UK
08-02-2003 16:11:23
 Re: Re: Re: Re: Disc Mowers in reply to Roy in UK, 08-02-2003 16:06:42
Curiosity killed the cat
http://www.kuhn-usa.com/internet/guideachat.nsf/(Fiches)/D3BB071AB3180BF6C12567BB004AAEF8?OpenDocument&Langue=US&Site=us
paul
08-02-2003 16:23:32
 Re: Re: Re: Re: Re: Disc Mowers in reply to Roy in UK , 08-02-2003 16:11:23
Thanks! Finger conditioners are so unpopular locally (alfalfa) that I don't even know how they work, but never knew roll or finger machines were made in a 3-point version like that. Very interesting.
--->Paul
Roy in UK
08-02-2003 23:10:30
 Re: Re: Re: Re: Re: Re: Disc Mowers in reply to paul, 08-02-2003 16:23:32
Kuhn have an excellent reputation over here. They make mowers for John Deere too. Alfalfa is unknown over here, roller type conditioners are also extremely rare. I understand that finger type conditioners are no good for alfalfa as they knock the leaves off.
DAVE M
08-04-2003 09:26:09
 Re: Re: Re: Re: Re: Re: Re: Disc Mowers in reply to Roy in UK, 08-02-2003 23:10:30
I think that you would call it Lucerne
Errin OH
08-02-2003 10:09:04
Have you looked a Reese? They have a 8' disk. If intrestead, they do have a 6'9" Drum mower. Bit pricey though.
jls
08-03-2003 19:31:33
 Re: Re: Disc Mowers in reply to Errin OH, 08-02-2003 10:09:04
some 9'ers have a pivoting tongue, my deere folds narrower than buddies 7' NH sickle machine. also I don't get the poor mouthing flails in 'falfa. you mow it GREEN and damp. I guess it makes sense if youre in Arizona on irrigatted ground & 5%humidity but east of central Ok & Ka you never have to replace a set of conditioning rolls again.
