brush cutting
sky
08-01-2003 17:02:16
I've got to knock down/mow some dry grass and sage brush.Problem is its very dry here and there are some rocks hidden in the weeds.What implement is best suited.I've got a 9N to use.I was thinking maybe a drag then disc? Any ideas?thanks
evielboweviel
08-03-2003 10:49:56
 Re: brush cutting in reply to sky, 08-01-2003 17:02:16
I would drag first.
2. pickup rocks
3.drag
4.pickup rocks
5.disk
good luck
Huckleberry
08-02-2003 21:18:24
Watch out for rocks! I don't know why but a rock can break that steel blade or crack it and it breaks later under a stress that it normally could cut. You won't necessarily know it when you hit the rock but later...rocks are hard on equipment.
larry
08-02-2003 15:02:33
kick the weeds with your foot if they break off use the drag if not use the disc and go slow if you have rocks
