WOODS BUSHHOG
COWMANSAM
07-31-2003 03:05:26
ONE OF MY GEAR BOXES HAS MILKY FLUID AND I WAS WONDERING HOW TO DRAIN IT. IT IS A 10 FT AND IT IS ONE OF THE OUTER BOXES.
hay
07-31-2003 03:17:00
 Re: WOODS BUSHHOG in reply to COWMANSAM, 07-31-2003 03:05:26
look underneath to see if there is a drain plug. some cutters have them and some do not. if no drain plug then you will have to use a suction gun to remove the fluid from the fill plug hole. also try to tip the cutter on the side of the fill plug hole and you should be able to get most of the old fluid out.
