Sidewinder, Model H, brushhog........
Win
07-29-2003 19:35:49
I have a 5400 John Deere(2wheel drive)..My brush hog is a Sidewinder 6ft. Model H. Even with the mover set at it's highest level, it stops turning in heavy weeds/grass.... Am I doing something wrong?
Free Bird
07-30-2003 05:50:17
 Re: Sidewinder, Model H, brushhog........ in reply to Win, 07-29-2003 19:35:49
HERCULES SERVICE PARTS IN MINDEN CAN HELP YOU WITH ALL YOUR SIDEWINDER PROBLEMS CALL 1-800-566-8359. ASK FOR PAUL OR KEN
Charles
07-30-2003 05:48:40
I have a SW model 66 which uses a tire for a slip clutch, I am having to adjust it for the same reason. I will remove shims and recheck. I am told the SW is the Hog to have for heavy cutting.
AP
07-29-2003 19:59:52
If yours is equiped with a slip clutch, it probably needes adjusting. I am needing adjusment specs for slip clutch on a Sidewinder 215 batwing. So if anyone has a owners manual or know how to adjust slip clutch with single large nut in the center, I would appreciate information.
Thanks
Huckleberry
07-29-2003 19:58:38
sounds like you need to tighten your slip clutch.
