What type of Tedder?
John in IN
07-27-2003 18:21:28
I have been looking at tedders and see there is two distinct differences in designs. One is called a rotary and is probally is what I have seen the most of. The other is a pull type and I don't know how to describe it but H&S builds one. Any way which works better and in what kind of hay. Thanks
bob
07-28-2003 15:34:25
 Re: What type of Tedder? in reply to John in IN, 07-27-2003 18:21:28
Cant go wrong with Kuhn GT-440 4 spool. pto powered. Very pleased with mine. I'm new in the hayfield but the veterns were very impressed w/it.
kyhayman
07-28-2003 13:45:03
I use a NI brand (made by Tonutti). They 2 baskets are great machines. The 4 baskets are a little light in construction. I have never had any trouble with 2-2 baskets we have, the 4 basket (3 years old) has been a real pain, lots of breakdowns) In your previous string a lot of folks talked about a tedder not being a good choice in alfalfa, I disagree. To ted alfalfa you have to run it a very few hours behind the mower. You get the same shatter and bruising you get with a conditioner with lots less moving parts. I have a haybine that has been parked for 10 years now (except for soybean hay, can not get the disc mower to behave in them).
Jerry D in NC
07-28-2003 19:10:35
 Re: Re: What type of Tedder? in reply to kyhayman, 07-28-2003 13:45:03
KYHayman,
I don't disagree that a tedder will work in Alfalfa but I get better results in hay appearance leaving it in the swaths the MoCo lays it down in. You are absolutely correct about tedding it right after the mower cuts it as the leaves are still on tight. The Sun exposure grays out more of it if it is spread out. We used to run a tedder behind a JD 920 Discbine and spread it out within minutes. Would tedd it again on day 2 either at night or at 5 AM to keep the most leaf on. Had several times more gray and yellow hay than the customers would buy. Had to sell it cheaper. Now we leave it in the swath and roll it once with a rolabar rake and it is green and dry. Makes some pretty hay in the same number of hours. Always seemed to get dirt and dust in it since it would be bedded down on the ground with the tedder.
Tim(nj)
07-28-2003 11:05:59
You mean a reel-type tedder? They are gentler on alfalfa than a rotary tedder, but I find they are not as effective on grass hay as a rotary tedder. Pequea makes a reel-type tedder, also.
Hay Dr
07-27-2003 21:43:02
H & S uses Sitrex for much of their out sourcing
