ATV sprayer ?
tra
07-27-2003 06:19:07
Has any one ever made a small boom to attach to atv and a spot sprayer to spray small hay fields? Don't know much about spray nozzles but wanted like a 10 foot boom just to cover a few acres.
Matt Clark
07-28-2003 11:50:41
 Re: ATV sprayer ? in reply to tra, 07-27-2003 06:19:07
Bought the 14 gal sprayer, and made the boom (8 ft) from 1" light square tube. Used nozzles from Blaines, and looped hose between nozzles. Adjusted height and spacing (needed 2 more nozzles) to get adequate coverage. Spent about 2 days getting things set right and about $75 on parts. Might have been cheaper to buy the boom to begin with, but I'm not sure what (if any) nozzles come with it. That's where the cash is... I don't have any problem with flow. Put pressure regulator on it, and with all 6 nozzles going, the pump cycles on and off, as it can keep up (1.7 gal/min???).
Matt Clark
07-28-2003 11:42:31
Jerry D in NC
07-28-2003 10:27:43
Agri Supply sells a couple of them. Go to the URL below and it should bring you to page 12 of the catalog. There are 3 options for the ATV
ksbob
07-28-2003 08:11:25
one thing you might want to check is how much flow would be required for the number of nozzels for a 10 foot boom and how much output the pump on the atv sprayer would have. The atv spot sprayers I have looked at seem to have small electric pumps on them designed for one nozzel - more than one and you may get a drip system instead of a spray system.
TimV
07-27-2003 15:08:30
Tra: Check out Northern Tool (northerntool.com) they have (or used to have, at least) an ATV sprayer similar to what you're looking for.
