JD 24T Plunger chamber getting hot
Black Creek Far
07-27-2003 04:05:48
I have a JD 24 T that the plunger chamber is getting hot to the touch by the slides. I have tried to adjust the pads because it is very sloppy against the slides. Even after adjusting the pads it is still sloppy when the plunger makes a round. You only notice how sloppy it is when you run it around by hand after breaking a shear pin. It don't seem to slam or rattle when it is running.How much play, if any, should there be between the pads and the slides? Thanks
ET
07-28-2003 11:42:52
 Re: JD 24T Plunger chamber getting hot in reply to Black Creek Farm, 07-27-2003 04:05:48
There are rollers on the plunger that are probably siezed up and gone.
Tim(nj)
07-29-2003 10:30:35
 Re: Re: JD 24T Plunger chamber getting hot in reply to ET, 07-28-2003 11:42:52
Had a 336 that did that. IF the rollers are gone, chances are the roller track is worn out, too.
Larry
07-27-2003 20:17:35
I don't know. But...I'm guessing...you're hanging in the bale case, rubbing the side (s) hard, generating heat. I had a 214JD...couldn't keep shear pins in it...finally pulled the plunger out and took my welder and welder up the pads to near original dimensions...and it was like a new baler!!!! I simply used 7018 and built up and then smoothed up a bit with my grinder and put back in and adjusted per the JD manual..and then adjusted a time or two after that. worked GREAT.
