a c roto baler
Delbert
07-26-2003 05:08:16
Anyone use their a c roto baler this year? I baled about 400 bales with mine worked good. Used it behind my m farmall just flip it out of second and let it tie the bale. Don,t need live power unless it is a wd or wd45 or jd with hand clutch you would have to set there and hold clutch in for a few seconds. Without live power you can rest your leg. How did your baler work?
chuck
07-28-2003 19:17:30
 Re: a c roto baler in reply to Delbert, 07-26-2003 05:08:16
i have finished one fescue pasture and baled it for winter graze--tho if it doesnt rain --i may need it before then--i used no string becuase i dont intend to pick it up. i baled over 700 in the fescue--also another 500 of alfalfa--i like the baler--my neighbors think im nuts. i found a white top for $125.00 it needed a return spring on the twine arm..no longer available and found one on a junk one in a hedge row. im looking for others as i dont know what may break next. i like the baler real well and use it behind a wd or a jd520..i like the wd better tho.
