488 haybine rollers
shannon
07-24-2003 00:11:33
does anyone recover the rollers on these? or is there anywhere cheep to get them?
Rick
07-29-2003 09:28:22
 Re: 488 haybine rollers in reply to shannon, 07-24-2003 00:11:33
I had the same problem with my NH 488. So I tried cutting out all the bad sections with a utility knife and I used Windshield (rubber) sealant (that they use to replace car and truck windsheilds with) and a plastic spreader to spread it out. You can buy the sealant in caulk size tubes for about $7.00 at you auto parts stores. Use latex gloves because it doesn't come off the skin very well. I tried it on my top roll and it lasted 3 years before I had one large piece loosen up.I used about 4 tubes on the top roll. It's worth a try.
Bruce Denny
07-28-2003 05:05:03
If I knew what these where I could let you know if they are "recoverable" or not. We recover rollers of all types with a wide variety of rubber. We also make new rollers. If you had a print or other information on these I could have them quoted for you. Ph. 262-857-2361
Fax 262-857-9483
Bruce Denny
TGIN
07-25-2003 04:26:28
I need the same thing . I talked to a guy yesterday that got all the rubber off his with a air chisel then welded flat bars on like the hesston rollers . Says it works like a new one . They wanted about $700 each for new ones I was told .
Steve from New Holland
07-24-2003 18:56:13
Interesting question. I never heard of anyone doing this. Steve
