New Holland 271 Hayliner questions????
JHunt
07-20-2003 23:56:59
I am trying to get this 271 baler shaped up and have a few questions.
Where can I get the clutch plates for the flywheel clutch other than NH, if at all(no good NH dealer near me) and how much can I expect to pay for them at NH or otherwise? Is there a kit that comes with the plates, springs and bolts or do you have to buy it all individually?
Can someone give me a description of what the spring is like that holds the twine fingers in the parked position? There isn't a picture in the manual that you can tell anything from and presently the spring is hooked to the left knotter frame and doesn't look too kosher to me along with having about 1/4" of play.
How do you adjust the spring tension on the bill hook roller "keeper"? I doesn't say much about that in the manual either. I also need the springs as they are very different from right to left.
This baler is acutally my friend's and he lets me use it in exchange for upkeep on it and cutting his field. This baler used to bale flawlessly until he let another neighbor borrow it and he let it set out all winter uncovered. The chains froze up and skipped time and broke the needles among other things. I have been gradually working this thing back into shape but it is hard to know if you've accomplished anything when you only bale 150 a year or so and it would sometimes bale 50-100 bales without missing a tie and sometimes 10 or 20. I finally got the thing up to my house and spent the better part of a day adjusting everything and fixing some obvious problems. I doesn't help that it has been cobbed on by previous owners, either, when I don't know enough about it to know how everything is supposed to be. The clutch is the big thing now as chunks of the plates are sticking out between the springs. Money is a issue more than usual since the baler doesn't acutally belong to me and I'm not planning on baling more than 400 bales a year with it.
I appreciate any and all constructive responses. Thanks.
Kelly C
07-21-2003 06:01:42
 Re: New Holland 271 Hayliner questions???? in reply to JHunt, 07-20-2003 23:56:59
Cant help with all your questions but can on some.
I would look for a used clutch plate. Maybe a old timer knows how many models would interchange.
Twine finger spring on my 68 is hooked to the right Knotter frame (from behind).
The spring for the bill hook cam. You can get from NH. Should be cheap. If not let me know I have a few sets of knotters out in the shed.
JHunt
07-21-2003 21:15:32
 Re: Re: New Holland 271 Hayliner questions???? in reply to Kelly C, 07-21-2003 06:01:42
Thanks for the reply, Kelly. I checked out your pages on your 68 last night after I made this post and got some good info from them. I guess the spring for the twine fingers must actually go there. Works okay, but it looks like if the spring had any more slack it would let the fingers drift in front of the needles. The spring on it doesn't look to be stretched, but may not be the original, either. Are the clutch plates that high priced that it would pay to look for used ones? I was thinking about going to an outfit that relines clutches and brakes and see if they had any friction material that could be used in there if it looks like they are going to be more than I want to pay. Looks like the are simply 6" diameter discs of lining with possibly a hole in the center. I am afraid to take it apart until I have something to put back in there as the baler will still work the way it is. I will get all 3 springs plus the one for the trip arm if I have to end up going to my dealer. My past experiences there don't make me look foward to it, though.
paul
07-21-2003 21:37:14
 Re: Re: Re: New Holland 271 Hayliner questions???? in reply to JHunt, 07-21-2003 21:15:32
I have a 270, which is the same as a 271 except for the hitch & an extra pto joint you have.
I had the exact same deal as you with the clutch plates. I believe just one of mine was in pieces, & I believe it was about $25, but that is some years ago, and my memory is foggy. Perhaps I got a set, I do not remember? Bet it was close to a decade ago tho.
That spring doesn't look right to me either, but it is hooked on a wire tied to the back, & there is a little bit of play too. Seems odd, but it works so I've never touched it.
Setting outside, the bane of any baler!
--->Paul
