JD No. 5 mower
Nancy
07-20-2003 20:57:51
Anyone have a picture on the hook up of a JD No. 5 sickle mower to an AC170.
Or have any drawing of home made Hookup.
bobg
07-21-2003 11:08:51
 Re: JD No. 5 mower in reply to Nancy, 07-20-2003 20:57:51
Nancy,
Go to the link below and it will show you numerous options to hooking the #5 up.
bob
Delbert
07-21-2003 07:18:53
Nancy not sure i can explain this so you can understand this but here goes. The # 5 mowers have two bolts at each end of the hitch anyway take those two bolts out. There is a bushing in each end save those for later. Now you can bolt your 3 pt to the mower use the bolts you took out of the mower. If you have a 3pt hitch. And then you will have to have a hydraulic cylinder to raise and lower the sickle bar. You only need single action cylinder meaning just one hose. Now that i have totalLY confused you maybe someone else will explain it to you better.
