What do you call this thing?
glenshoe
07-19-2003 15:59:37
A friend told me he bought a device which, when attached to a truck bed or wagon, would pick up square hay bales from the ground. It is ground driven and can save a lot of effort. I'm not talking about a "stackhand" or some new device. This has evidently been around a long time. Anyway, I would like to know what it's called and keep an eye out for one myself. thanks. Glenn
rhudson, strong arm?
07-20-2003 10:12:53
 Re: What do you call this thing? in reply to glenshoe, 07-19-2003 15:59:37
seen one that craddled the bale, then an arm triped and swing the bale up and over in a wagon, truck bed, whatever it was clamped to. it was called a "strong arm" not sure if that was a brand name. ground wheel driven.
greenbeanman
07-20-2003 10:10:59
There were basically three kinds of bale loaders in the '50s and '60s being used.
As mentioned, the pop up kind that in my opion THREW the bale at you, and two versions of the other.
Think of the latter two versions as a metal trough setting at a 45% slope on two wheels.
An arm/tongue was at the side of the loader and slipped into a stake pocket to facilitate pulling the unit.
The trough had a link chain running up the center of it. Every few links had a link that had a projection that would catch the bale to move it up the trough. Usually at the top was a short flat area for a bale to rest on until you removed it, or the next bale up would kick it on off the end.
I mentioned that there were two kinds, one was ground driven as mentioned, the other had a one cylinder gasoline engine to drive the bale moving chain. I preferred the latter since just driving faster wouldn't bring the bales up faster.
With these loaders a driver and stacker can load and set in a stack 1200 to 1600 bales in a long day. I know, I worked one summer for custom bale haulers. The year would have been about 1964.
I received 1� cents for each bale when it went on the truck, and another 1� cents when it was placed in the stack. Good money for a young kid, but very tiring in the heat of the summer. The worst were heavy rain soaked bales that HAD to be removed so that the next operation could begin. Most were alfalfa bales.
Similar devices are available today to move bales from trucks/wagons into haymows. They are electric.
glenshoe
07-23-2003 04:37:11
 Re: Re: What do you call this thing? in reply to greenbeanman, 07-20-2003 10:10:59
Thanks for the very clear description. Glenn
Paul Janke
07-20-2003 09:55:03
I used one hooked to the side of a semi trailer. I think the wheel was about 8' in diameter. I heard it referred to as a ferris wheel. We loaded about five tons with it, and as I remember we broke either one or two bales.
greenbeanman
07-20-2003 11:13:22
 Re: Re: What do you call this thing? in reply to Paul Janke, 07-20-2003 09:55:03
I forgot about that type of loader when I wrote about the others. I've have seen them, but never worked with them before.
Doug in IL.
07-20-2003 05:11:55
I have a early 1970's Graves bale loader in pretty good shape I would sell. I'm in West Central Illinois.
John A
07-19-2003 18:54:31
Glenshoe, If this loader brings the bale into a cage then the bale makes a 90 degree turn and goes straight up and turns out at the top. This loader is called a "pop-up bale loader" These ol loaders work pretty well but have a tendency to break bales. or
is it the type where the bale slides up a 45 degree angle, in a shallow trough, and a wheel driven chain brings it up. This kind is easier on the bales. I think they were called "easy bale loader"
Hope this helps,
John A.
glenshoe
07-20-2003 10:11:24
 Re: Re: What do you call this thing? in reply to John A, 07-19-2003 18:54:31
Yeah, it's the one with the shallow trough. Okay, bale loader or easy bale loader. Thanks, guys. Glenn
Tractor Dan
07-19-2003 18:21:12
im not sure what its called either but i know where there is one its been sitting in the pasture as long as i can remember the old farmer said it worked real well befare he got baler with kicker
