combine
Randy Reed
07-17-2003 16:25:21
Does a Ford 3000 tractor have enough horsepower to operate a John Deere 30 combine?
larry
07-19-2003 07:43:45
 Re: combine in reply to Randy Reed, 07-17-2003 16:25:21
my uncles ran there ihc 80 with m for years i think your 30 has bigger cylnder and maybe less plugging what i did was just cut the heads off and then cut with a haybine latter it made better straw and easier on the combine
firedog
07-18-2003 14:07:18
Should be plenty if you have a live PTO
firedog
Brad Gyde
07-17-2003 19:19:15
I don't know exactly how big a JD 30 combine is, but I run a IH no. 80 pull type (believe it is about a 6' cut) with a 1953 Massey Harris 33 (35- 36 pto horsepower). It's a little hard starting, but once she's moving it runs it good (no live pto either)
Hope it helps,
Brad
Wayne in Pa
07-17-2003 17:00:04
If your 30 combine has an engine on it their will be no problem. If it's a pto combine you may need more tractor. We ran a 30 with a JD 40 but the combine had it's own engine.
Hope this helps. Wayne
