Trouble with NH 67 baler
Jeff
07-17-2003 14:18:23
I need some help please? My new holland 67 baler broke the drive chain and now the shere bolt on the knotter has broke and I replaced it and now the neddles do not make it back to the home position before the plunger hits the stop arm. I have it in time I think but it is still braking the shere bolt evertime. Any help? Thanks Jeff
Scott
07-18-2003 09:55:50
 Re: Trouble with NH 67 baler in reply to Jeff, 07-17-2003 14:18:23
Check if it is slipping at the knotter brake and letting the needles fall too quick.
John in IN
07-17-2003 19:59:01
I had a similiar problem with my 68 when I was timing it. I followed everything to the tee and when I jogged it around ( just easing on and off the P.T.O.) it hit the safety. I believe I advanced the timing mark a tooth on the knotter sprocket and it worked fine. I thought that should move up the knotting process. Hope it works. Let me know.
Jeff
07-18-2003 11:43:07
 Re: Re: Trouble with NH 67 baler in reply to John in IN, 07-17-2003 19:59:01
Thanks John that did the job I had to advance it 2 cags and it works great. Thanks lots now I can finsh the field. Jeff
John in IN
07-18-2003 15:28:49
 Re: Re: Re: Trouble with NH 67 baler in reply to Jeff, 07-18-2003 11:43:07
I am glad it helped. Good luck.
Ridr
07-17-2003 15:01:33
It is not in time , run your plunger until the main crank is straight up between the timing marks cut into chassis , then check to see where your timing marks are on the tine bar drive and needle drive, if you can't find the marks (or they are gone you will have to time it by hand
