New holland 268 baler problem
sean
07-16-2003 10:41:25
Can anyone tell me the cause of this intermittant fault.A bale ties correctly how ever one side ties and cuts correctly and the other ties correctly but appears to only cut one string and comes out with a long length from the next bale to be tied, which of course only ties on the one side.
Chip S.
07-16-2003 13:17:43
 Re: new holland 268 baler problem in reply to sean , 07-16-2003 10:41:25
My first guess is the twine finger on the bad side is out of adjustment. The pointy edge should come up and just barely miss the needle as the needle point passes the twine disk. It then should catch the twine so the billhook can tie and cut both strings at once.
