Nh bale wagons
jim s
07-13-2003 22:56:51
Do any NH bale wagons unload bales one by one onto a hay elevator & are any models better than others ?
Bob
07-14-2003 17:12:09
 Re: nh bale wagons in reply to jim s, 07-13-2003 22:56:51
I have no connection with the links below... just noticed them on the 'net. I used to own a 1010 and a neighbor had a 1034. Good machines.
Link
Link
http://www.cochranfarmsupply.com/UsedEquipment/usedfarmeq.htm
Kirk Affeldt
07-14-2003 13:11:35
Jim
My dad and I had a NH 1012 bale wagon. It held 56 bales plus a couple extra. This model could single bale unload or dump. One thing that you should keep in mind is the machine still needs a person to guide the system a bit when it is unloading. The NH bale wagon were seen alot in southeastern Minnesota but unfortunately many of the smaller diary farms have gone away. At our farm auction in 1995 our twenty year old machine, always stored in the shed, went for $4500. They were are aand still are a great way of handeling bales of hay! Good luck!
Mark S.
07-14-2003 12:56:06
Jim, I am working on the pre-build models of the brand new New Holland BW 38 and BW 28, If you wait a couple of months you could buy the latest and greatest model. I would be glad to send you some information on the new models. The BW 38 and BW 28 unload the whole stack at once.
Ghostrider
07-14-2003 05:48:47
The 1010 model will single bale unload. It holds 56 bales. There are implement dealers on the web that specialize in these things. Do a web search. I have a 1010, and have been told the later models have a better load rack return carriage. Mine has been bent and fixed several times. Also, look for 1st table welds.
Mark
07-14-2003 07:34:28
 Re: Re: nh bale wagons in reply to Ghostrider, 07-14-2003 05:48:47
I have never seen a bale wagon in this area (eastern Ky.) but saw several in use out in Colorado. My question is; how do they work? Do they scoop the bale from the field and then automatically stack it on the wagon? man, that's a neat trick.
kyhayman
07-14-2003 08:53:36
 Re: Re: Re: nh bale wagons in reply to Mark, 07-14-2003 07:34:28
Drive over to Harrodsburg, KY. I have one.
To answer the earlier post a 1034 does single unload to an elevator. One reason I got a 1034 instead of a 1033. Wish I had the 1033, way faster to dump and run. About 12 of us right in this area have either 1033's, 1034's, or the newer 1037's.
Mark
07-14-2003 11:06:19
 Re: Re: Re: Re: nh bale wagons in reply to kyhayman, 07-14-2003 08:53:36
hayman,
how about telling me how it works. I'm just west of Ashland in Greenup county. Seems as if most folks have gone to rolling their hay, then again, this isn't horse country and we all know a horse, that noble animal, couldn't possibly eat rolled hay. HAR!
kyhayman
07-14-2003 12:09:19
 Re: Re: Re: Re: Re: nh bale wagons in reply to Mark, 07-14-2003 11:06:19
Hi Mark,
Know that area well, I used to be County Agent in Carter County back in '91-'94.
Here it is; but it's long:
Based on 1034 to current production (mine is about a '76 vintage). I use a 336 Deere baler with a 1/4 turn chute to drop the bales on edge. Make 5 rounds around the field early and roll and wrap for baleage. Then I can cut in straight lines (makes it a lot easier, real bugger to turn a lot with these things).
Lift chain picks up bales and puts on 1st table, conveyer chain shoves it over, when bale #3 gets on the first table it causes bale #1 to push a lever. This trips the table setting 3 bales on table 2. Each sucessive trip of 1st table pushes bales back on 2nd table. When you get 5 runs of 3 on 2nd table it trips stacking in load rack (against receeding forks). When you get 7 runs in load rack back into barn and load rack tips to verticle. Push off feet push you off the stack. Then forks retract to home and back to stacking. All self contained hydraulics, only 4 non hydraulic moving parts. At 1 (or more levels you want a tie tier so the stack doesnt split, pull a lever and it does it)
I use a 1410 Case/DB and leave it hooked all season. Capacity is 105 bales, the way I run my ties I get 99 per load. Takes 17 minutes on level ground to load. Rolling ground usually me about 30 mins per load. Takes me longer to drive to the barns and back the beast in than load. When you dump you have a nice neat rick of hay. If I start raking at 10, bale and then stack I can have 600 or so in the barn by dark. If I can get my dad to bale for me I can do 1200 a day easy. Have used lights and put 1800 in.
Barns were simple, I cut out the crossties in my tobacco barn driveways (need 12.5' verticle to dump). I get help early in the am or late to rick the hay in the sheds of the barn (not wide enough). My drive ways are 14'w, sheds 12'w center of posts and I have to have 12'4" w to get in. Also built a quick, cheap shed on one barn and planning more. Set 2 rows of cedar posts on 14' ctrs. Tacked up a plate and put up rafters. 72' long, 28' deep, and 13' on the low eve, 16.5 on the high. Got under $3000 in it including labor.
Mark
07-14-2003 18:20:49
 Re: Re: Re: Re: Re: Re: nh bale wagons in reply to kyhayman, 07-14-2003 12:09:19
kyhayman,
thanks so much for that informative explanation. carter co. agent huh?! I live at Oldtown and if I ain't mistaken Kelly Hall.....don't know her married name, later became agent in Carter county. I went to school with her older sisters. Carol Ann runs the REA in Grayson and Sherry Rae has some kind of government agency job as well. I put the Subway in Grayson circa '92.
If have any groundhogs and coyotes needin' killin', I'd sure like to come help you do it sometime.
kyhayman
07-14-2003 18:56:53
 Re: Re: Re: Re: Re: Re: Re: nh bale wagons in reply to Mark, 07-14-2003 18:20:49
Yeah, Kelly followed me, then Larry Rogers and Myron Evans. I knew her Carol, didn't know her other sister. Anytime you want to come cut down the coyote and groundhog population, come on.
Mark
07-14-2003 19:13:22
 Re: Re: Re: Re: Re: Re: Re: Re: nh bale wagons in reply to kyhayman, 07-14-2003 18:56:53
I didn't realize there had been that many agent changes in so short a time period. Ol' Baily was agent here in greenup co. forever, or so it seemed. i don't even know who the agent is now. i always figured those were pud jobs.....else Baily wouldn't have worked as long as he did....he-he!
keep your eyes peeled down in that country for a hand cranked JD corn sheller. been looking for one a long time but they weigh to much to have shipped, going to have to find one close enough to drive and pick up.
kyhayman
07-14-2003 19:19:25
 Re: Re: Re: Re: Re: Re: Re: Re: Re: nh bale wagons in reply to Mark, 07-14-2003 19:13:22
Bailey was, well, unique. Didn't strain much. It's a job you can do as much or as little as with as you want. Will watch for a sheller. If you would keep an ear out for anybody looking for a NI 2 row wide, 8 row husking bed picker.
Mark
07-14-2003 19:30:56
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: nh bale wa in reply to kyhayman, 07-14-2003 19:19:25
okay, i will.....but be danged if I know what that is!
drop me a email at: Jump_trap at msn dot com.
bailey is as windy as a sack full of.....well, you know and as long as the flies weren't too bad, he never bothered to swat at them too often.
Dale in IN
07-14-2003 05:17:19
The mod 1034 will do that. or stack all at once. Picks up 105 bale per load. The 1033 is just a stacker. These are pull type models. Very heavy on the tungue. I pull a 1034 with a 1959 JD 730 Diesel. Dianoed 60 HP just last night. Wagon is mean to back from their bulkyness,18' long and 10'wide.
Rick
07-14-2003 04:30:46
Yes and Yes
