Mott hammer knife mower
mike mix
07-13-2003 07:48:49
Just purchased a Farmall cub with a mott hammer knife mower. Is this company still in business? Anyone know who carries parts?
thanks
KIM MCLACHLAN
06-02-2004 13:07:11
 Re: mott hammer knife mower in reply to mike mix, 07-13-2003 07:48:49
LOOKING FOR THIS ATTACHMENT HAMMER KNIFE MOWER BY MOTT. ANYONE KNOW OF ITS WHEREABOUTS IN OR AROUND THE FINGERLAKE REGION? ITHACA N.Y. INTERLAKEN SENECA FALLS WATERLOO SYRACUSE TO GIVE A FEW AREAS CLOSE TO US THANX KIM
Randy Messer
07-13-2003 19:24:28
Mott is no longer in business, the company was bought by Alamo (see link below). You will need to work thru a local dealer to order parts, as Alamo does not work direct with customers.
Many of the common bearings, etc., can be crossed by working with local NAPA or auto parts supplier. Takes time, but got most of my needs met there.
I've found several sources of aftermarket parts which work fine for my Mott mower - Montage Enterprises (http://www.montageent.com) and Flail-Master (http://www.flailmaster.com) - blades, belts and similar wear items.
Had most of my OEM parts obtainable from Alamo - but getting somewhat pricey. Good mower, very pleased with operation on my Cub.
Hope this helps!
John in IN
07-13-2003 12:39:23
Do a search of this forum using "MOTT". 2nd page line 21 or 22 I think should have info to help. Check some other lines also. TSC does carrie blades in our area. Napa is a good source for bearings or any other good parts store. I used a three-point 6ft. Mott Mower with finish blades for 4 years and only had to replace an oil seal. Heavy built mower.
John in IN
07-13-2003 12:42:00
 Re: Re: mott hammer knife mower in reply to John in IN, 07-13-2003 12:39:23
Make that line 27.
