JD hydraulic cylinder
darrellr
07-13-2003 05:04:17
I have a hydraulic cylinder for a John Deere B that I am trying to rebuild. The overhaul seal kit from JD is no longer available. Any ideas where I can get replacements seals for it.
52BMAN
07-13-2003 18:05:00
 Re: JD hydraulic cylinder in reply to darrellr, 07-13-2003 05:04:17
I just rebuilt my 'B' cylinder. I got new seals from a local company that rebuilds cylinders. For $20 it works great, no leaks. Good Luck with yours.
Dan
07-13-2003 15:21:34
I checked on seals for an A cylinder a while back. The kit was not available but most individual seals were. Just need a thick wallet. Otherwise if you take the seals and cups to a hydraulic supply place they may be able to match it up. Nothing very exotic.
morgan
07-14-2003 07:37:33
 Re: Re: JD hydraulic cylinder in reply to Dan, 07-13-2003 15:21:34
I just did a rebuild on an 'A' cylinder, John Deere had the complete KIT, cost 63 dollars with freight. Part # AR21770 R- just make sure you have the new type piston or you won't be able to get the correct piston seals. IF you have the old type piston #A3458R and still have the old seals on it, then just go to a seal store and let them match them up. The piston rod 'V' seals and shim's can be bought a Deere for around 30 bucks. hopes this helps-morgan
Rick
07-13-2003 06:22:29
Try Bailey Bearing out of Tenn. They have lots of cylinders
