Tractor match for the JD346?
lpc
07-12-2003 23:27:11
I spoke up for a Oliver 77 wfe with a loader to run the baling chores at least. I'm wondering what you folks opinion of my also getting an aquaintance's JD346 to run behind it. Will that be a good match as far as weight/power and work output? This is only my second tractor and first with a loader. Plan on making a squeeze for the loader for bales.
Rick
07-13-2003 06:17:54
 Re: Tractor match for the JD346? in reply to lpc, 07-12-2003 23:27:11
I think you are going to be light and maxed out far as power. JD 346 is large capacity baler in its day. The hyd on 77 were not that stout so you won't be lifting that many bales either. I grew up on Olivers. The 100 series or 50 series would work much better for that size baler. JD 14t would be better range baler for 77.
