PTO in gear??
billylisa1997
07-11-2003 20:15:37
Hello, I recently purchased a ferguson TO-20 and the only way I can get the pto to work is to put it in gear. Am I missing somehting?? Please help
LH
07-11-2003 22:54:37
 Re: PTO in gear?? in reply to billylisa1997, 07-11-2003 20:15:37
If the tractor doesnt have live pto (which I dont beleive your TO20 has) the clutch has to be engaged for the pto to work. It should still work in neutral though as long as ya dont have the clutch pushed in
paul
07-12-2003 11:38:39
 Re: Re: PTO in gear?? in reply to LH, 07-11-2003 22:54:37
As said over in the Tractor forum, some old tractors also had a ground-speed pto option. The pto would be driven by the rear axle basically, faster or slower or not at all in neutral.
However, there should be controls to _also_ run the pto at constant speed while in neutral or any time the clutch is released.
I do not know much about Ferg, so I do not know if your tractor is like this for a fact.
--->Paul
Tim(nj)
07-12-2003 15:50:22
 Re: Re: Re: PTO in gear?? in reply to paul, 07-12-2003 11:38:39
If it is a 2-speed Fergie PTO, pushing the lever down puts it in ground speed. Pulling it up runs it off the engine. Middle is neutral. This applies to tractors with 2-stage clutch and live PTO, never had an early Fergie without live PTO, so this may not apply . . . .
