What is it (2nd try)
Paul
07-06-2003 13:42:56
We are looking to find out what this old piece of farm equipment may be.
I posted here once before and some suggested that I post a picture of this item. It is on the implement photo page under "unknown" by Paul Williams.
The only information on the implement is the following:
Lacta
225 E
60/MIN
The name Lacta is in cursive with the lower tail of the L underlining the rest of the letters in the name with a slight wave to the line.
It was found in a Middle Tennessee barn that was at one time a dairy farm.
Any help would be appreciated, as it was my better half's parents farm she would like to know what this is if possible.
Thanks,
Paul
Alvin NE WI
07-06-2003 18:39:40
 Re: What is it (2nd try) in reply to Paul , 07-06-2003 13:42:56
It has been many years since I have looked at mine, even though it is upstairs in the 'junk room". I know it is a Delaval and there are a bunch of disc in the bowel. How many I don't remenber, haven't run it for over 30 years. It was a armstrong crank also.
Alvin
paul
07-06-2003 18:14:09
As the others say. Hope you can find the other parts laying around.
In the old days, only cream was of any value to sell, so the cream was seperated with a centrafudge (sp) - the cream was hauled off to the creamery (butter & cheese making) and the skim milk was kept to feed to hogs, mostly. Would make them pretty runny, but put a lot of weight on them fast! :)
As time went on, all the milk was hauled to the creamery where they seperated it, and some customers could buy back the skim milk for their hogs.
Then, the creameries started finding markets for whole milk & skim milk, all changed in maybe the early '60s around here.
--->Paul
Hugh MacKay again
07-06-2003 14:53:36
Paul: I notice since post Bob's suggestion of De Laval. The one we had at home was IHC. Most of the mainline farm equipment manufacturers in that era had a seperator. The one we had was bought new in 1932 the year we got electric power. My dad said they had a straight hand crank model before that. They sold cream to local creamery and fed the skim milk to hogs and beef calves. I know Oliver and MH also had there own brand seperator.
Hugh MacKay
07-06-2003 14:43:03
Paul: I commentented on your photo as well and my best guess is a cream seperator, less the milk handling parts. It I asume has a hand crank as well as electric motor. The electric motor over rides the hand crank. When you turn that crank there should be a pedestal in about a 8" recessed area that turns. The centrifuge which does the actual seperation sits on that pedestal. The hand crank was used if power was off as well as beginning and end. I remember my dad starting with hand crank as the centrifuge was quite heavy as well as high sped, and electric motors of that era didn't have great starting capacity. There was a housing around the centrifuge and the housing contained two spouts; one for cream and other for skim milk. A steel type bowl sat on top to place the whole milk for seperating, it had a pet cock in bottom to regulate flow of milk to centrifuge. The spouts were set at 45 degrees to one another. These usually had a swing out platform for cream container as they wanted it quite close to spout to a void spill with the valuable product. The container for skim milk usually sat on floor.
This is just a guess as light is not doing your photo justice, along lines of detail. Usually the milk handling equipment was stainless steel, although I suspect some of the early ones were not stainless but some type dip treatment.
Bob
07-06-2003 14:25:49
It's obviously a cream separator. The "60" refers to RPM's that you hand-cranked it to keep the separator bowl at the proper RPM. You are missing the tub, or tank the whole milk was poured into, along with the sheet metal spouts, and probably the separtor bowl. I am not familiar with this brand. Have you done a web search for LACTA?
If you can't find anything for your brand, search for DeLaval Cream Separator, which is another brand similar in appearance to yours.
