MF 32 sickle bar mower
Frank Mason
06-14-1999 19:22:24
Can anyone tell me about the Massey Ferguson 32 sickle bar mower. 3pt? pull-type? width? Good mower? Age?
Thanks!
Bob Semrau
06-16-1999 07:57:36
 Re: MF 32 sickle bar mower in reply to Frank Mason, 06-14-1999 19:22:24
Frank, I have an MF 32. It is 3 PT mounted, and you need to have one stabilizer bar connected as well. It is MUCH more convenient to use than a trailer type, IMHO. It has a pitman, though. An MF 31 or 41 didn't have a pitman, I believe. Mine is a 7 foot, but according to the manual it also came in 6 foot. My manual, which I got from Agco, has a 1965 copyright date. It does a good job mowing, and is MUCH easier to attach than say, a Ford 501.
Agco replacement parts are expensive for it, though. I have been kind of looking for another one as a parts machine. One thing, though. If your PTO shaft isn't standard (like the 1 1/8" on my Ford Jubilee) you need an adapter that doesn't change the PTO shaft length. I found this out the hard way, as I cracked the cast piece with the drive pully on it because my adapter stuck out too far. I was able to get the piece welded, and it has held together for 2 years now. My other solution was to install an aftermarket 1 3/8" conversion PTO shaft in the tractor. Also, you don't lower the mower all the way to the ground when mowing - according to the manual the hitch points should be between 19" and 20" off the ground.
I hope this helps ...
