JD 346 Wire Tie
Tucker
06-27-2003 18:31:50
Can anyone tell me how to time my 346... Chain broke and stroke is now off...
Jim B
06-28-2003 04:27:58
 Re: JD 346 Wire Tie in reply to Tucker, 06-27-2003 18:31:50
Tucker,if it is the frt. chain,clean hay out of chamber,install chain snugly,rotate flywheel in direction when pto is running(counter-clockwise)on compression stroke(plungerhead moving towards rear)trip needles,when needles are flush with inside bottom edge of lip in balecase, points on plungerhead should be even to 1/2 in.to rear of needles.If not correct take gear off on left side that has a 1/2 in. stud in it line up needles and plungerhead and reinstall gear.Next step is to purchase operators manual.Hay on ground can't wait for that!!If you have problems post back.Jim B
