Rotary Mower Size for 8N
ClayB
06-26-2003 05:38:15
I'm going to buy a new rotary mower to use with my 8N to cut an old twenty acre mixed grass hay pasture that is on flat ground. I'll be doing this a couple times a year.
Does anyone have an idea as to what brand/s, mower weight and size I should be considering or to stay away from?
I'm thinking that a 5' deck size should be about right but, I'm not sure of if I should go with a light duty, medium duty or heavy duty mower.
What size deck, weight and brands do you guys use behind your N's?
Any help or comments would be appreciated.
Thanks.
Tom A
06-26-2003 06:45:10
 Re: Rotary Mower Size for 8N in reply to ClayB, 06-26-2003 05:38:15
I've got a 5' medium duty Howze that came with the tractor when I bought it. It is fine, although sometimes it makes the front end a little bit light when I raise the hog while going up a steep slope...and I have lots of steep slopes. I really beat up the mower on the slopes, but have been able to spot weld the deck together about once a season and it is giving me good service.
So, if your land is rough you probably shouldn't go over a medium weight or else get front weights for the tractor. If it is no more than rolling hills or flat you can probably do a heavy duty without problems.
H Otis.
06-26-2003 13:06:23
 Re: Re: Rotary Mower Size for 8N in reply to Tom A, 06-26-2003 06:45:10
I would not recomend front weights on a Ford N. The front end is not sturdy enough to handle it. If you don't believe me, ask the folks over to the N board.
paul
06-26-2003 06:29:08
I don't know, but get an ocr - over running coupler. It will keep you from running into things! See the message above yours, do a search for OCR - much info on them here in the archives. You need one with an N. This is not the same thing as a slip clutch.
--->Paul
