Bushhog
CT
06-25-2003 08:35:51
I've just become a first time tractor owner and along with the tractor I purchased a used Taylor Way 270 6' rotaty cutter. The cutter does not have safety chain guards on the front and I have concerns about the safety of using without. What should I expect to pay for chains and do they really keep the driver safe.
Brent
06-25-2003 13:05:22
 Re: bushhog in reply to CT, 06-25-2003 08:35:51
I don't have a guard on mine either, but have been whacked by sticks and a rock or two. If I get hit hard enough I will probably go ahead and put a guard on eventually :-) I also don't operate with other people or animals near, and make sure I shut down when a vehicle drives by on the road.
BB
06-25-2003 10:10:55
I run a 6' rotary cutter without chain guards. I never run it if anyone is anywhere near. Have never had a problem although I occasionally hear of someone getting hit by something thrown from under a cutter. Commercially available chain guards are about $150+. Many people just buy chain, cut it in pieces, and make their own. I do think it would cut down on the stuff thrown out.
BB
06-25-2003 19:42:12
 Re: Re: bushhog in reply to BB, 06-25-2003 10:10:55
Just an added comment. I don't know what kind of tractor you have. I have a JD 950. I am sitting pretty high above the cutter and the front edge of the cutter is fairly close to the rear of the tractor. I think it would require a ricochet for something to hit me, rather than a direct hit, as the angle between me and the cutter is pretty steep. If you have a smaller, lower tractor it would be more of a problem/concern.
ct
07-02-2003 11:53:23
 Re: Re: Re: bushhog in reply to BB, 06-25-2003 19:42:12
My tractor is a '66 Ford 3000 Diesel and it seems like the wheels are pretty close to the cutter. I think I'll probably get chains from the Manufacturer but I'm still doing research on rubber products. The guy at the New Holland dealer said that people are using 3/8" x 8" conveyor belt rubber and making their own guard. Are you familiar with this type of guard?
Thanks for the response
Gary The Roookie Farmer
06-25-2003 19:52:21
I noticed on my bushhog (or more properly: rotary cutter) that if I put a chain guard on the front of it the chain would have a real goood chance of being hit by the blades.
BB
06-26-2003 05:58:14
 Re: Re: Re: Re: bushhog in reply to Gary The Roookie Farmer, 06-25-2003 19:52:21
Yes. There have been some posts on other sites where people made their own chain guards and failed to notice that. The blades shortened those links for them. Oops!! You would either need to install the chains far enough out to miss the blades, or make the center few chains a little shorter.
