JD seed plates
Robert J Spence
06-14-1999 09:23:58
I have a model 247 JD planter and used my smallest plate ( # h1302b ) which in the manual says it is for small corn. With this plate I seem to get a fair # of doubles on the sweet corn seed I am using and wanted to know if anyone had a line on a smaller plate ? ( the manual lists a plate # h2571b and a # h697b for extra small corn. ) Can anyone help me out?
Redneck
06-14-1999 12:00:03
 Re: JD seed plates in reply to Robert J Spence, 06-14-1999 09:23:58
Your JD dealer has a complete list of plates for the seed size number of the corn, probably an F-14 or F-15. They can match you up. If you don't know what the seed size is check with the seed store, they can tell you, also alot of the seed sacks will recommend a plate for you.
Robert J Spence
06-14-1999 12:10:47
 Re: Re: JD seed plates in reply to Redneck, 06-14-1999 12:00:03
Thanks for the reply.
The seed did come with a JD plate reccommendation of plate # JDT-24c however I don't think this is a plate for my particular planter is it?
Redneck
06-14-1999 12:57:54
 Re: Re: Re: JD seed plates in reply to Robert J Spence, 06-14-1999 12:10:47
To be perfectly honest I'm not sure. That plate is a 24 cell but doesn't ring a bell with me. Most of the plates for JD planters are basically the same, up through the 7000 series planters. Give that JDT-24c number to your JD dealer and see what they come up with for your planter. BTW the older planters used or came with metal plates. JD now has plastic plates which are cheaper and work well but have different numbers. The plastic plates should work fine in your planter but check with JD.
