JD 336 baler
Ray
06-21-2003 20:00:51
Shear bolt breaks when plunger safety is engaged. It seems like the needles start moving to quickly, but only does it about every 8-12 bales. Any ideas, I checked the timing and it is ok.
Ray
06-24-2003 20:41:43
 Re: JD 336 baler in reply to Ray, 06-21-2003 20:00:51
Thanks for the help. The slip clutchs look wore. Ray
Jim B
06-22-2003 04:33:37
Ray,the needle brake needs tightening or brake pads replaced.It is at the top above and left of knotters.It holds needles in home position when baler trips to tie.When tripped it should take slight force to move needle frame.One other thing is not to have too much air in tire on fly wheel side if in rough ground.Hope this helps.Jim B
RickB.
06-22-2003 03:19:16
Check timing again. Check knotter brake tension. Check plunger stop linkage adjustment.
