Water Well Drilling Implement
FlyingVRanch
06-21-2003 04:39:06
I am thinking of fabricating a 3-point water well drill so I can punch some small, cheap,wells in my pastures for my cows. Most wells would be less than 50 feet. I am considering using the jet technique where I would wash down PVC pipe by using a pump.No rotating is necessary here. My ground is all soft clay and sand. I would need to build a hoist rack for the pipe on back of the tractor similar to a real drilling rig. Has anybody ever heard of such an arrangement, and does anybody have any suggestions or ideas? Thanks in advance!
ATW/WA
06-25-2003 15:25:29
 Re: Water Well Drilling Implement in reply to FlyingVRanch, 06-21-2003 04:39:06
I drilled a hard rock and shale hole about 50 foot with a "HYDRA DRILL" several years back. Worked great, with your soil you should have no problem. you may want to build a small pond and use some bentenite clay to carry any gravel up to the surface. HTH ATW/WA
