Planting brome
Doug Rogers
06-20-2003 08:29:43
I have 20 acres that I will be putting into brome this fall. I was previously in weeds. Beginning lat year I mowed it a few time then this year I have disked it 4 time and springtoothed it two more time to get the weeds down. For the most part this has worked howeve I still have quite a few weeds that keep coming back however I would say that 90% of the ground is bare. Sould I spray with 24D or something like that yet this year or will I be safe ignoring the few weeds ond going ahead and planting this fall knowing that if they become a bigger problem later I can always spray them then. Was going to use "roundup" this year till I checked the cost of the stuff.
Matt Clark
07-03-2003 12:16:19
 Re: Planting brome in reply to Doug Rogers, 06-20-2003 08:29:43
Glystar Plus - 2.5 gals = $58. Use the heck out of it in my new trees. Mix as recommended and spray...
kyhayman
06-20-2003 19:52:06
Definitely spray. Those are good prices on the generics, even regular Roundup Ultra isnt bad in the 2.5 g (paid $129) at the 1 quart rate that's just 12.90 per acre. With 2,4-D (at $49.00 per 2.5 plus surfactant) it's going to run upwards of $9.00; about the same as Roundup generic and the 2,4-D won't get your grassy weeds or some of the perennial vines. No way I can disc ground 2/3 times that cheap.
Jerry (AL)
06-20-2003 16:48:10
The generic version of roundup around here is $90 for 3 gallons at the local farmers co-op. I'm not sure if it comes in smaller quantities or not.
greenbeanman with another
06-20-2003 09:11:32
I remember hearing that when a lot of the CRP grass was planted, they required planting into a stubble crop like cane.
Since the ground is now bare, would it be better to get a small growth of sorghum stubble before planting the grass later on?
Ridr
06-20-2003 08:39:42
your better of killing all the weeds, roundups patent expired this year so you can buy it generic a whole lot cheaper. You can also keep working a disc on it all summer and let the sun do the work for you (if it ever comes out )by fall it will look like a tilled garden. don't forget to do a soil sample , just my thoughts
Steve450
06-20-2003 19:04:54
 Re: Re: Planting brome in reply to Ridr, 06-20-2003 08:39:42
Just got a 2.5 gal. jug of "clear out", generic round up for $89.00, Round up was $70.00 for 1 Gallon!
ShepFL
06-20-2003 11:42:11
Now that is some good news on the pricing of ROUNDUP. Thanks!
As you can see I only do this part time otherwise I would have known this earlier.
ShepFL
Bob G
06-20-2003 08:55:28
You could have used Roundup in the beginning and it most likely would have been cheaper in the long run. I would just till again at this point.
Bob
