NH 488 haybine body work
Lee
06-18-2003 18:11:10
The flat metal area behind the cutterbar (NH 488 if it matters) is rusting.... several perforations already! Any suggestions for repair. I was thinking fiberglass or sheet metal, but that is just a rookie's guess. Any advice re the do's & dont's of whatever I should use would be greatly appreciated.
Thanks!
Catskill Pete
06-19-2003 20:38:13
 Re: NH 488 haybine body work in reply to Lee, 06-18-2003 18:11:10
The obvious answer is to replace or weld in a patch,,,But I'll tell you what I did with a neighbors machine. He had a 479 with the same problem. So as a "temporary" fix I put in a plastic liner left over from a dump truck bed repair. Well the "temporary" fix lasted 5 years until he sold the farm, and as far as I know its still working. You can get the heavy grade sheet from various places, I got mine from Farmtek. But its sold as liners for truck beds and manure spreaders in sheets.
Lee
06-20-2003 14:45:14
 Re: Re: NH 488 haybine body work in reply to Catskill Pete, 06-19-2003 20:38:13
...and how did you attach it?? Pop rivets by any chance?
Catskill Pete
06-20-2003 15:57:25
 Re: Re: Re: NH 488 haybine body work in reply to Lee, 06-20-2003 14:45:14
Laid down a base cover of roofing cement over the old metal, then attached the plastic with #10 screws and nuts.
